pond pump wire | on ElectriciansForums
Discuss pond pump wire in the UK Electrical Forum area at ElectriciansForums.net
Coventry
I've been to quote on a job today where the customer had dug a pond / water feature in to the garden. their is no raised edge around the pond, it will go grass, edging bricks, water all at about the same level. it's a very minimalist look he is going for. the edge of the feature is about 2M from a fence. getting down to level with the pond via the fence with swa is straight forward enough. pond pump is submerged with pre fitted cable. how do I get from wiska box on fence to pump? is burying some plastic conduit 600mm deep the only option? and does plastic conduit offer the required protection for buried cables?
cheers, adie
This might be a little overboard for what the gentleman wants, but I installed one of these recently and instead of hard wiring the pump, I put in an outdoor outlet, mounting/strapping the conduit onto a tree stump next to it so it still looked like a natural piece in the garden. I know it has a wire coming out of it, I just used that to put a chord with a plug on it, like you would a washing machine or dishwasher.
The reasoning for the additional nonsense was because those pumps can be cheap and don't always last long so if it's hardwired, the owner will have to undo everything when they go to replace the pond pump. Also, the wife of the guy likes to hang lights and decorations for her garden parties so the outlet gives her more options for plugging stuff in.
Sorry if this was more confusing than helpful, I avoided specifics on measurement and current or voltage ratings because it's all different here.
My pond pump just goes in behind the reeds and drops into the water, the wire that is. It is black and that's how it's designed to go. Plugs into to an outside waterproof socket mounted close by, cable hidden between side of pond and fence, no way it could get hit or anything.
Have you considered metal copex to provide mechanical protection to the flex between connection box and pond edge. I don't think plastic pipe alone will suffice. The copex will terminate neatly into your connection box. Be careful to use a cable gland as the flex leaves the copex to enter pond.
Reply to pond pump wire in the UK Electrical Forum area at ElectriciansForums.net
