Pond pump | on ElectriciansForums
Discuss Pond pump in the Australia area at ElectriciansForums.net
P
peteelecs
I am having problems with a pond pump the RCD will trip after about 10 minutes every time I reset it but the mcb does not trip at all any advice would be appreciated
Hi
I installed a feed to a pond pump via swa from ring indoors via rcd unit last year it all tested up with no problems had a phone call recently they said
every time i switch pump on via isolator outside the rcd unit trips !!!!!!!!!!!! I asked questions and found out they had baught a second hand pump from ebay !!! and it was knackerd one lesson learned when i check faults allways go for the simple solutions and d,ont all ways reach for your test gear as a lot of faults can be found visually
Richard
Reply to Pond pump in the Australia area at ElectriciansForums.net
Indeed, the same electrician also made me realise you shouldn't have two RCDs in the same circuit!! Respect to the trades.... !
G
Booster Pump Needs Reset Daily Hi, I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank. Normally...
gnulab123
G
