A
ambrad
Hi all
After having the shower circuit upgraded to 10mm cable, new shower and pull switch the tripping times recorded for the existing rcd are as follows.
76ms x1 65ms x1(180) 28.6ms x5 38.3ms x5 (180). These times appear not to meet the standards for the minor works cert and im after suggestons as to my options. The existing rcd is about 10 years old and on asking the occupier has not carried out regular operation through the test button. I know the easy answer is to change the rcd, but is there something else that could be causing this that i can consider.
look forward to you suggestions
