Poor Zs | on ElectriciansForums
Discuss Poor Zs in the UK Electrical Forum area at ElectriciansForums.net
stuart569
Getting around 0.15ohms on a 400amp supply. It's a 4-core 240 and the run is about 120m. The spark at the job says he thinks the cable has been jointed twice due to being dug up and damaged. Its hrc cartridge link fuses. Had a squint around and reckon the max Zs is 0.09? Is this correct?
Haha most likely not! That was my suspicion but it's always good to have someone more experienced confirm. Now to fix this issue is it possible to just run a new earth wire rather than replace the cable?
It wouldnt be following original route. Will have to go round conveyors etc. a longer run but less hassle. What size would you recommend? Just go the whole hog and run in a 120 earth?
Now you say it I see your point with the shorter fault path back through the armour rather than the new earth? Thought about changing to A 400amp MCCB but max Zs values are still no good for the current situation. Also thought about trying to tt it but don't know if this would be suitable
How much longer will this make the earth run compared to the cable?
Can’t say I like the idea.
Me neither. I don't know what the UK regs say but where I am it's not allowed, an exported earth that's external to the supply cable must follow the same route and be strapped to the cable. Even if your local regs don't specifically exclude this, I would still suggest it's not good practice.
To be honest I’d be looking for the joints and replacing them. To my mind the modern cast joints don’t have sufficient cross bonding for the armours. I’ve always put more copper braids in than the manufactures recommend, also a lap of braid around the armours before the constant pressure spring.
I don’t know if you can still get them but one company made joints with a support ring that slid under the armours and the braids were clamped with a jubilee clip. A sound conection.
Reply to Poor Zs in the UK Electrical Forum area at ElectriciansForums.net
