Porcelain tiles potentially over weight limit: is this a big issue?
Without thinking too much about it (DIY job), we bought these tiles, and now I realize we might have made a mistake: Maddox Grey Concrete Effect Porcelain Wall and Floor Tile | TileMountain - https://www.tilemountain.co.uk/maddox-grey-concrete-effect-matt-porcelain-wall-and-floor-tile
I am going to use them to tile the splashback of my kitchen. Right now there are small ceramic tiles, which I will remove and replace with the new ones.
The wall is a party wall (masonry) and I assume is plastered... which I've just figured might be a big problem.
If I got it right, the weight limit for plastered walls is 20kg/m2, my tiles should be 20.6kg/m2 excluding grout and adhesive (so probably around 23-24kg/m2 in total?)
For the adhesive I was thinking about using the Mapei Keraquick Wall & Floor Rapid-Set Flexible or Adesilex P9.
Is this going to be a huge problem? I am not tiling the whole wall, the highest I will go is 75cm where the cooker is and about 48cm in the rest of the wall. Is this really likely to be an inssue?
Porcelain tiles potentially over weight limit: is this a big issue? for the Original Article on Tiling Advice Forum
