Afternoon all,
I require some wisdom from the fountain of knowledge that is electricians forums.
Last week I was carrying out portable appliance testing in an a factory that I carry out alot of work in, The factory floor has been wired with IEC 60309 sockets throughout, all fine so far. However I have noticed that certain appliances have had there standard fused plug tops removed and replaced with IEC 60309 plugs (Commando) as there were no standard socket outlets located nearby.
This surely is unacceptbale as these appliances require fuse protection, the MCB protectiong the IEC 60309 sockets is likely rated at 20A.
For example one item I came across was a soldering iron, the cable from the soldering iron to the IEC 60309 plug was 0.75mm! The appliance does have an internal fuse but this does not cover the flex feeding it. ???
Does anyone know of any IEC 60309 plugs available with built in fuse protection or am I just going to have to use adaptors.
Any help is Apretiated
Cheers
Dave
Cheers
Dave
