Portacabin supply | on ElectriciansForums
Discuss Portacabin supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ste s
Hey all,
Got a few questions about a portacabin that's going to be used as an office block. Unfortunately I have not seen the cabin and doubt I will until it turns up unannounced no doubt. The cabin is 75m away from the closest supply which will be run underground in ducts (already in place). I am planning on supplying a 63A single phase supply using 25mmsq 3C swa (due to length of the run). The supply is TNS so no need to earth rod. Do I need to make any other considerations? Input greatly recieved.
WHY 63a? phone and ask the cabin supplier what is in it ? how big is it ? what will be in it? to many variables in your question M8
It's going to be used as a office for 12 staff. I've been told it will contain a lighting cct (few flourescent fittings), ring main(pc's, fax etc) and a max of 3 heater radials. The size is 40ft x 20ft. Unfortunately I can't get a full spec or even a viewing as it's all getting sorted higher up than me then thrown in my lap! It's a case of planning for every eventuality.
i used to wire cabins / modular buildings , and theyre all different so i would speak to the supplier to check the loading and whether it will be single or tpn .
This
There will be an electrical planner at the company who will have done all the calculations and will know exactly what they require.
I'm actually very surprised that information hasn't been forthcoming already. In my experience there will be a contractor doing groundworks and services and they will be told evrything needed before the building is sited. eg position of concrete pads and exact positions and requirements for mains intake and water intake etc.
This
Maybe Ste s is the electrical planner.... :tongue3:
Ha v good. No seriously I now believe this cabin is on the cheap so I'm just going to wait and see what turns up.....and believe me I've known the guy who's ordering it for some time. Cheers for all your input, beginning to wonder if any proper companies exist anymore.
In other words, it's being bought secondhand so no information on anything!! lol!!!
Reply to Portacabin supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
