Portasol soldering iron | on ElectriciansForums
Discuss Portasol soldering iron in the Electrical Tools and Products area at ElectriciansForums.net
Hi guys
Looking to invest in a soldering iron for a job and heard portasol were good so have been looking at the super pro gas kit. What type of nozzle would be best for soldering leads onto a led tape kit and what would be the best type of solder ?
Regards
Graeme
I have an older version of the Portasol soldering Iron.
It has something like 6 different heads.
One is a knife blade, another is for hot air, the rest are all for soldering.
I would use the smallest tip for LED tape, to confine the heat to the smallest area possible so as to prevent damage to the tape.
I have a cheap and cheerful gas soldering iron which is a Godsend for when there's no power available, it looks like this except mine is black;
[ElectriciansForums.net] Portasol soldering iron
Like I say they're helluva handy but they're not my first weapon of choice because they don't have good temperature control so overheating solder joints and components being soldered is too easy to do. Also the exhaust ports may it unsuitable for electronics because if you're not really careful you burn things in the surrounding area whilst using it.
Any small pointed tip or small flat tip would work with standard fluxed radio solder.
And keep the vent upright or you will definitely damage it , gets the fingers too if you don't watch it lol.
Edit . Sorry thats slow 3 again.
i really like my weller pyropen, the temperature control works really well, it is no match for a bench with digital temperature control though.
not cheap though and i got a really big discount on it, the guy i bought it off went to his supervisors to get me the best offer he could
draper rosin core solder is realler good anand get a good solder sucker
this one is very good
Reply to Portasol soldering iron in the Electrical Tools and Products area at ElectriciansForums.net
These may be ok http://www.farnell.com/datasheets/63120.pdf
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
