position of fused spur, isolation | on ElectriciansForums
Discuss position of fused spur, isolation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DTSFA
hi
for fitting a supply , single phase, to a lift, 6A load. We state a local fused double pole fused switch, rated at 13amp.
does BS 7671 state for fixed equipment, where the local isolation switch should be positioned ?
thanks
Local Isolation Switch means to me, that it needs to be.... local, or at least close enough, to be in plain sight, also needs to be easily or readily Accessible!!
What sort of lift only requires a 6A supply to it?? lol!!!
Reply to position of fused spur, isolation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
For a TN system neutral is deemed at earth potential.
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
