Possible airlock We have a sink, washing machine and shower in a ground floor utility room. Cold water is supplied from a loft tank. This otherwise only feeds a hot water cistern upstairs and all other cold taps in the house are mains fed. Cold water to all the items in the utility room has stopped running after we did some work elsewhere in the house. Thinking it must be an airlock we have fed mains water through the shower cold outlet via a garden tap and hose. We opened the sink tap until the water was flowing, then turned that tap off and left the mains on until the loft tank overflowed. Alas, there is still no cold water coming through. We would be grateful for any advice please.
Possible airlock to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
