Possible fire risk? methinks | on ElectriciansForums
Discuss Possible fire risk? methinks in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Could I put wagos in one of them? Would it be classed as MF? :)
Well...the cables have strain relief:D
But Wagos are only certified as MF compliant, if they are in a Wago enclosure.
Extract from Wago website
It’s important to note that the connectors and the enclosure do not qualify on their own as maintenance-free accessories. This is because an accessory is defined as the whole equipment and may comprise of two separate products – the connectors and the enclosure – both have to be certified for use together and installed according to the manufacturer’s instructions.
That is just a technicality:mad:
Another comedy vid :)
My fav is still that pic of underground cable joint wrapped in a biodegradable shopping bag.
Reply to Possible fire risk? methinks in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
