Possibly the worst wall I have ever worked with, | on ElectriciansForums
Discuss Possibly the worst wall I have ever worked with, in the Australia area at ElectriciansForums.net
E
eskimo39
Can anyone here give me some advice? I am currently doing a full rewire on an unoccupied house but having some trouble chopping in backboxes.
All external walls are fine but the internals are a real nightmare. They are made of a kind of soft breeze but have like a large 2" cylindrical hollow running down it every six inches or so. When trying to chop in i just end up breaking through the other side and cannot for the life of me get a flat back to fix to.
Anyone have this before.
Also the customer wants rid of the pull switch in the bathroom so I was going to chop a box in but found out it is a stud. No problem I thought as I would just use a plasterboard backbox but it is Lathe and Plaster. Will a plasterboard backbox work in this? Or am I best removing a section of lathes between 2 studs and replacing with plasterboard?
Cheers
EDIT: Sorry should read worst wall not works wall.
Re: Possibly the works wall I have ever worked with,
If the wall is those hollow blocks you can usually fix backboxes with screws through the sides if the hole is neat. Chemical anchor might also be an option but it can get messy.
Cheers
I had this problem with the breeze blocks no too long ago was an absolute nightmare. Try and get a baton of wood screwed into the second breeze block and screw backbox to that.
As above chemical adhesive will also do the job if the batons fail...
have had this problem before. some internal wall are only 2" thick. what i have tried in a couple of cases is to fit 2 boxes back to back, plaster them in with a couple of nuts and bolts through them.
Expanding foam in the hole let it go off cut flat then fix as said before into the sides of the box to the wall, the worst walls and I hope you don't have the mis pleasure of working on them are the one made entirely of flint that have had a cement slurry pored around it huge air gaps voids and the slightest hammering dislodges most of the surrounding wall ahhhh it was hell!
Bonding is great for this sort of job. Either an old bag of the stuff or mix it up with warm water to make it go off quick. Sticks like the proverbial to a blanket and if you gobbo your boxes in while you're doing it they won't even need fixings as the bonding will hold them in no problem.
Cut the holes for the boxes as best you can. Use some easi-fill 20 to make good the hole back/sides and let it go off, then fit the back box as normal (trim if necessary). If you use gripfill/chemical type fixings it's a pain in the bum to take the box out later if needed.
Edit: OK that took too long to type then :p
if its stuff Im thinking of its likr china and an absolute bum to get boxes in due to the formers between both outer skins best bet is the bonding type plaster when your cutting in boxes and chasin Rather you than me
My house has these dam blocks, and i have done others with them.
I just chop the box in as normal and go through to the hollow.
Once they are all cut in, i use bonding plaster, half fill the hole, push box into plaster.
Then a couple of screws pushed through the fixing holes.
Never, ever had a problem.
I use BG dry lining boxes in lath & plaster walls. The tabs allow for a thicker wall and push outwards rather than hinge out. Worth a try.
Reply to Possibly the worst wall I have ever worked with, in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
This thread can now be closed, as I seem to also have space in the box for the first switch. Revised diagram below. Thanks folks.
