Hi Everyone
One of my customers is getting some decking put in at the back of his house. It's designed so you can walk straight out the back door onto it. He says he wants 3 post lights fitted to it.
There is a 13amp switched fused spur inside right next to the back door. I'll be using this as a feed. I intended to drill through the wall and run conduit down the back wall until it was underneath the decking and into a IP65 junction box. From hear I intended to use SWA cable to connect the post lights up.
I haven't ever wired up these sorts of lights before and wasn't sure if SWA would be easiest. Some people have advised me to use T&E cable and put it inside flexi conduit. Would this be suitable mechanical protection? None of the cables will be buried, just left on the soil underneath the decking or clipped to the decking itself.
Just looking for some pointers and trying to save myself some hastle!
