Ok im looking at changing my Potterton EP2000 Room thermostat over to hive to channel to work with hw/ch .. the only problem is wiring no 5 . Which is I guess the switch to motorised valve .
Sorry I meant programmer/timer and I'm replacing it with a programmer and thermostat hive unit
If you look at the back of the ep2000 there is a wiring diagram. Straight forward job when you take a look at it.
Any idea why the blue/yellows wires is being used . Is this just to make them easier to pick out . And what should I do with connections 5. As there is only 4 on the hive .cheers
The blue and yellow are being used because that's the colours of the second and third cores in that type of cable.
Terminal five's purpose is clearly identified from the wiring diagram on the back of the ep2000 and from looking at the connections you have there.
We can't tell you how to do it as the forum doesn't allow us to give step by step instructions
Yes because you probably have a Y-plan as they are used for HW on and off. 5 is common on the EP2000 which is linked to live.
Winchester
Potterton EP2000 Room thermostat wiring
DIY Electrical Advice
Mjpuds,
Mjpuds,
