Hi all,
Thank you in advance for anyone who is able to provide some advice to me.
I am not an electrician nor a plumber but I feel competent when it comes to these sort of things.
I am looking at installing a NEST into my house to start turning my home into a smart home (im an IT manager nerd) and I just want to make sure I know exactly which wires to put where.
I am going to get the 3rd Gen NEST and I have a Potterton Promax HE Plus combi boiler and a wall mounted thermostat powered by batteries.
This is the wiring guide on the boiler plate:
[/URL][/IMG]
Followed by the wires into the boiler itself:
Finally the wires to the thermostat:
Thermostat is running on battery at the moment but ideally I would like to install the Nest unit here (I know it requires power)
Finally is the wiring diagram for the Nest itself:
So on assumptions:
I do all the sensible stuff like power off, isolate etc.
Then remove the cables from the left hand side.
Using some new 3core I wire the live and neutral from the boiler into N/L on the heat link. I leave all the hot water alone as it is always on (I believe)
I am unsure which cable is the call for heat? Is it the black one from the thermostat into the switched line in 1?
I am assuming that the Earth & Grey cable in Live out 2 are going through to the thermostat.
Basically I would like some advice when it comes to the wiring so that I doing do something bad.
Thanks,
Tim
So on assumptions:
Thanks,
Tim
