Potterton Suprima 80E main electrics dead | on ElectriciansForums
Discuss Potterton Suprima 80E main electrics dead in the Central Heating Systems area at ElectriciansForums.net
Hello,
I have a Potterton Suprima 80E and it was functioning well today.
We had a power cut to the house and a few minutes later the power was restored. Now the boiler does not power up at all. No red led or programmer activity. Just completely dead. I have checked the fuse socket leading up to the boiler and the fuse is ok. I have checked with a mains tester that power is indeed going into the boiler electric main. Could it be the fuse inside the boiler that has blown?
I really don't know what to do, any help would be greatly appreciated.
thanks,
matt
Turn off the power at the spur (fuse socket).
Open the door on the right hand side and you will see a single screw just above the aperture for the controls/lights etc
Undo that screw and you can then tip the side panel forwards to get at the PCB.
Hello,
Thanks for the quick responses and help. Much appreciated.
I managed to open up the boiler and get access to the PCB. Instructions from PartsArena. The boiler was manufactured in 1999.
I could see that power was getting into the PCB from my mains tester so I checked the onboard fuse 3.15A which had turned black. I replaced this fuse with another 3.15A one, and hey presto, it sprung into life again! Not sure what caused the fuse to blow, as the main spur fuse socket was fine and I checked it had a working 3A fuse in it.
I also read up about potterton electronics and how many people have had problems with the boiler 'lockouts'. There has even been a BBC watchdog programme about it from what I read! I was thinking I might need to buy a refurbished old 5102160 pcb for £50 (which I think is what is installed in my boiler), but then found out they are very troublesome after a few years (lockouts). So I saw potterton released the new 5111603 pcb for these models to solve the lockout problems for about £140.
There is a good site called Suprima-fix at Suprima-Fix for good information and fixes for Suprima boilers.
Anyway for now, I'm up and running! Thanks.
If you do go for a reconditioned PCB, I recommend an ebay user called Sarumlady. It is actually a man, not sure why he is using this name. He is a heating engineer, as far as I know, and he knows how to refurbish the boards and gives a guarantee and excellent support. Also gave me a very good fault diagnosis manual for Potterton boilers. Have fitted two of his boards and they are still both going strong.
Reply to Potterton Suprima 80E main electrics dead in the Central Heating Systems area at ElectriciansForums.net
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty 😜 1. Auto range multimeter (used on mains before when testing the...
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
