Power circuits problem | on ElectriciansForums
Discuss Power circuits problem in the UK Electrical Forum area at ElectriciansForums.net
Swrate
Hertfordshire
I've got a job for next sat and the client has said he has 6 floorboxes in his office and 3 don't work.they are on 2 circuits and when he resets the mcb the other mcb trips! I was thinking crossed legs between the 2 circuits but it must have been ok when installed. Any thoughts?
If you have an MCB tripping then there is a significant fault that can be found. If it turns out to be an RCD tripping it is less clear but as it is instant it should be easy to find.
You would have to provide more detail on exactly which boxes are powered by which circuits and what exactly happens when MCBs are on or off.
It sounds a bit like an interconnected circuit with a fault.
Reply to Power circuits problem in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
