T
tonychitty
with the new 17thregs requiring us to to fit rcd & rcbos etc, in the event of a power cut say while i was on holiday for example.because you have to reset the switch, when the supply is returned,there would be no power to say to my freezer or more importantly the sky+ box with 2 x weeks of home & away the misus would go ballistic,i know you you could put the freezer on a integral cct,or does no one think this is a problem ,it would be if you lived in rural areas with a TT system with the main isolator being a rcd,or areas with lots of power outages.
They would only trip off in the event of a fault on the circuit for the house, they wouldnt trip off if there is a power cut. So when power is restored from the supplier it would all go back on.
Anyone know any different? I have been to lots of houses with power cuts and nothing has tripped off!
If you are going on holiday unplug everything you dont need to lessen the earth leakage =0)
power cuts
Australia
tonychitty,
Mac,
