I am not trying to correct the power factor of a halogen, I am trying to ruin it.
Adding a cap will put a slight delay in the system. This delay will put the flickers out of phase with each other, 'hopefully' reducing the visibility of it.
This has nothing to do with powerfactor but Intefifciofactor . :) Use a SMP to change the frequency of the localized lamps.
As I said, i'm not sure it would work.
I am basing my assumption on the fact that the peak power would no longer be exactly at the same point due to the current lag.
As the two peak powers would not longer be in line it would delay the flicker.
The fact that this also would mess with the power factor was a secondary concern, so not really the best thread for it.
Where is my logic failing?
So what does SMP stand for?
Significant market power
Special Milk Program
State Management Plan
Service Management Platform
Strategic Management Plan
Safety Management Program
Sex, Money, Power
Simple Minded People
See Me, Please
Smoke More Pot
Standard Maintenance Procedure
All recognised international acronyms (there’s about 70 more).
Sex, Money, Power
See Me, Please
Smoke More Pot
:)- Must be an investment banker ! :)
SMP stands for Switched Mode Power Supply - Very clever device........
Because you can utilize it to change ac to ac , ac to dc, dc to dc and dc to ac at any frequency you like ! - almost a gift of the gods .....
that is those who can see them !
I assumed that is what you meant, just wanted to make sure.
No room for an SMP in this device, and the costs would be prohibitive.
Had a simple thought last night, just putting a run cap in parallel with the load would have a smoothing effect.
Another thought is the control circuit for this device has a 12v line, not supposed to be for external use, but have 'borrowed' it for testing before. It might be enough to run a few LEDs.
actually mate your 0.8 is not far out, the commonly recognised pf limit for lagging current is 0.85, any thing lower than this will be heavily penalised by vectoral summation metering and charges in rkwh units, lagging curreny caused by inductive loads is normally rectified by installing pf correction equipment (capacitor banks for example to reduce the financial costs
As a point of interest in a building with inductive load and poor pf the main tails etc are normally hotter than expected for the visible real load, hope this helps
the only time the pf figure is applied is when a circuit is being designed and there is known pf component, lets say a 10kw 400 V motor with a pf of .8 and eff of 1
the load in amp would be caalculate as
P/V / .8 / 1 = I
10000/400/.8/1 = 31.25 amps /3 = 10.41A per phase
P/V / .8 / 1 = I
10000/400/.8/1 = 31.25 amps per phase
should there not be a 1.732 in there as well?
What you need to remember about PF correction is that your only correcting up to the point the capacitor(s) are connected!!
So if you have a large motor that has a PF of say 0.60 and you apply correction to the terminals of that motor, your only correcting that lagging current in the cable supplying that motor, ...the motor will still be running at 0.60 lagging!!
Capacitor banks used to circumvent penalty charges from the DNO and normally connected just after the main protective device on the supply side of the installation. They Will do nothing to reduce the overall PF of the installation, that will remain the same. Only the DNO's meter and supply cable, will see the effects of the capacitor bank.
Power factor is defined as the ratio of the real power, between 0 and 1. It is the value given to a either inductive or capacitive. The capacitive is applied to electric circuits.
power factor correction
The Ranger,
nil26,
