Discuss Power Factor Question in the Electrical Course Trainees Only area at ElectriciansForums.net
Don't you mean power in KWsA 230V, single phase machine, draws a current of 10A at a power factor of 0.8. Calculate the power dissipated by the machine.
Is the answer 12.5A?
don't you mean power in kws
It's drawing 10A at pf 0.8A 230V, single phase machine, draws a current of 10A at a power factor of 0.8. Calculate the power dissipated by the machine.
Yes, it is indeed drawing 10A at pf 0.8, but how much does this machine dissipate?
you did the calcs with 12.5 amp and got an answer
Is it the correct answer though? That's why I'm here.
P = I x V ( 10 x 230 = 2300W or 2.3kw )
2300/0.8/230 = 12.5a
Scrap that it's asking for power not current
2300/0.8/230 = 12.5A
P = I x V ( 12.5 x 0.8 x 230 = 2.3kw )
I = P / V ( 2300/230 = 10a )
My answer is 2300w but I've been up since 4am I'm sure someone more knowledgeable will pop by shortly.
Has anyone been shown the fluorescent light example at college, with the PF correction cap being switched in and out of the circuit?
What will happen when it is switched out of circuit therefore giving it a power factor lower than unity?
I assume the current being drawn will increaseHas anyone been shown the fluorescent light example at college, with the PF correction cap being switched in and out of the circuit?
Reply to Power Factor Question in the Electrical Course Trainees Only area at ElectriciansForums.net
