R
rgf1
My installation has 2 strings. Sometimes the Riso test fails on one string - showing a Riso of less than 1 Mohm. Therefore it fails the start sequence. I have had the supplier inspect this after a failure and he has diligently checked for water leaks, fretted insulation etc. and he has remade the isolator connections etc. - just to dot the I's etc. He found no fault. The Inverter started immediately after this - reading 20 Mohms on each string when one is isolated.
It does seem to be something to do which rainy conditions and I am very near the sea which would perhaps give salt in the air.
I have developed a work round, which is to switch off string 1 - (which seems to be the fault string) let the inverter start and then turn String 1 back on. The Riso is then at 20 Mohms. The other weird thing is that once the inverter has started then both strings immediately read 20 Mohms. Even when one string is switched off to test the fault.
Both strings are putting out virtually identical power and there is no evidence that the output is affected at all.
Could this be an Inverter fault? As the Riso reading seems to be back up at 20 Mohms immediately.
Is there some form of test for this. I am not an electrical engineering expert, but I guess that if a megger was used, this would fry the panels etc.
I have also noticed that running on one string there seems to be a Temperature display - called Boost - what is this.
Any diagnostic help would be much appreciated.
