View the thread, titled "Power one 3600 OD" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
I have had a look around but cannot find an answer does a powerOne have REVERSE POLARITY PROTECTION ??? Like smaAn installer told me he seen an power one smoke today but i didnt Know the answer why only either the above or the mc4 may have been lose any advice or experiance of this ?? I have reversed polarity onceOn a sma but i simply swaped pos for neg with no damage etc ???????
Apparently, a Power One cannot be damaged by incorrect polarity - just high voltages. Seeing as some installers appear to be forgoing the actual design aspect of installing PV, it could well be that the installer frazzled the inverter with a high voltage.
However, unless the installer is a complete idiot, I'd imagine that a loose connection would be the most likely culprit - possibly because said idiot used a pair of pliers to 'crimp' his MC4 connections.
Really? The indoor or outdoor model? All the indoors we have used have been MC3, last one fitted was 4 weeks ago.
Seems I best offer some apoligies to Biggs.
I believe the indoors and outdoors versions are actually different generations of inverter, with the outdoors being the more recent (Hence mc4 rather than mc3) more flexible and more efficient. Have a look at the detailed specs. The indoors versions would be a fraction cheaper for me, but I do not use them.
Gents
To clarify on the points raised
Yes - all inverters have reverse polarity protection.
MC3 - Only available on indoor PVI-2000 + PVI-3600 (that are denoted UK on the product label)
MC4 - On all other string inverters inc new product releases.
The OUTD IP65 (universal) unit is a newer design than the indoor models
Rgds
A_S
I would like to say thanks to aurora for excellent customer service, I had a glitch on a pvi desktop, new firmware emailed same day and new SD card in post day after. Well impressed thanks.
Reply to the thread, titled "Power one 3600 OD" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
