P
Peter Woodford
Is this O.K am installing some sockets into my shed was going to spur off of socket inside through wall and out to shed. broad inside is rcd protected
Discuss power outside in the Australia area at ElectriciansForums.net
Hi Peter,how many sockets,any lights and how far is the shed away.Is this O.K am installing some sockets into my shed was going to spur off of socket inside through wall and out to shed. broad inside is rcd protected
I would put a fused spur by the socket intended to feed the shed into an IP rated adaptable box.In the shed i would do as you said in the 1st post,another spur,fused down to 3 Amp for the lights but i would keep the sockets to a maximum of 2.The beer fridge is most importantHardy anything really they will hardy be used just to charge bAttery for drill lawn mower and I pod
And beer fridge most important
You mentioned fridge and lights and potentially a 6x block extension lead, and although you say your not going to overload, the potential that someone else might do is there, so i would run a supply back to con/unit then it doesn,t matter mate.
If you do choose the other options, is the socket you are coming off on the r/main, or is that a spur, if its the latter, its a no no.
Reply to power outside in the Australia area at ElectriciansForums.net
