A
Andy625
I live in a house that was built in 1999. It had a Power Shower (pumped water from the tanks - not electric shower) fitted from new. We've had a couple of shower units where the motor in the shower has become either jammed or partially jammed, resulting in lots of noise and a little smoke on one occasion. Although the house has MCB's and an 30ma RCD (which the iron trips out regularly), whenever the shower's played up though, nothing trips. I assume as nothing is leaking to earth, and the extra current flowing is less than the 6A required to trip out the breaker.
The shower is powered from a spur off the upstairs lighting ring which has a 6A MCB in the fusebox. it has a two-pole pull switch just near the cubicle, but I cannot see any independent fuse. No-on'e ever touched the wiring in the house since it was built - we're the only owners. Does this sound like its wired correctly?
As the showers seem to fail on a regular bass, I'm thinking of putting in a fused spur with maybe a 3A fuse, so that the fuse will blow before anything starts getting hot. Does this sound like the thing to do?
