P
paul_in_luton
Hi All.
Apologies but I've just joined and couldn't post this in the DIY section where it should be.
I've seen other threads on this forum dealing with almost the same problem but I thought I'd try it anyway, so here goes. I have built a play barn/hut at the bottom of the garden for my teenage kids. Currently, when they want to go down there to play pool, table tennis, listen to music etc, they open a window in the conservatory, pass and plug in an extension lead that winds its way down the garden to the hut and off they go. Not ideal to say the least and probably illegal.
I’ve already cabled up two ring mains – 4 double sockets on each, one spur plug on the mezzanine and 6 separate lighting circuits. The only reason for having eight double sockets is that no matter where you put them, they always seem to be in the wrong place. The only stuff that’ll be running down there is a stereo, a small electric fan heater and the lights. Nothing too heavy.
I now want to make this safer so I’m thinking of taking a 50m length of 10mm 3-core SWA out of the back of the consumer unit in the house, burying it 500mm deep, complete with warning tape, instead of the extension lead. The SWA will then go through the concrete wall into the hut, via a metal junction box and on into a Crabtree 410/2B Starbreaker insulated 10 way consumer unit with switch disconnector isolator 100A. Then have two Crabtree 61/B13230 Starbreakers 1 module single pole type B RCBO 32A 6kA 30mA for the ring mains, one 61/B11630 for the spur and six 61/B10630 for the lights.
How does this sound? Comments would be much appreciated.
