Hi
I've now had a quote and just would like some opinion on this. Its not that I don't trust the proposal. Just after some thoughts.
We have an existing 2.5mm swa cable going to our outside office, the proposal is to feed of a 32amp RCBO in the consumer unit in the house (its an RCBO board) with a 2.5mm swa cable and connect this to the existing 2.5mm swa outside so its new circuit from the board, then feed this is into a non RCD rated consumer unit, as the circuit is being fed from is an RCBO so the office CU will be a standard100amp main switch CU with a breaker for sockets and a breaker for lights in the outside office.
Does this sound ok?
Does this sound ok?
