Just be careful when reading this info its always good to check that it relates to the panels PTC rating which means its factory tested to environments and conditions it will be subject to in reality; where as if it refers to the STC (standard test conditions) these factory tests may not match the natural environment in use and can be misleading giving values that differ in real installation termsNormally just the actual guarantee on what the panel will deliver- so a 250w panel with 0-+5w could be a panel anywhere between 245w and 255w- Hope this helps
Reply to the thread, titled "Power tolerance?" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
