M
marteee
Hi there
I'm after some advice, please (I'm by no means an electrician but I can follow advice/instruction). I want to power a small shed. It will be running horticultural lighting - maximum of 325w (two lamps) but mostly likely a single 200w lamp. There will also be a small fan (35w) and heater (120w), both of which will be thermostatically controlled. The fan will keep temps down when the lights are on, the heater will keep things warm at night (the shed's insulated) when the lights are off. Everything will run through a 3kw contactor relay.
I already have an outside socket, which is an RCD protected spur from the kitchen. Working backwards from the shed, i was thinking of putting a twin socket RCD in the shed, running 3 core, 2.5mm armoured cable from the socket back to a IP65 enclosure, and then having a short cable (with a plug attached) from the enclosure to the socket (as I'm assuming it's going to be a little fiddly to fit a plug to armoured cable). The total cable run from shed to socket will be around 13m, and with the exception of having to run the cable under one flagstone, all cabling will be above ground.
I'll only be running the system through the colder months - December through April, and as I'm living in rented accommodation I don't really want to have to go through the rigmarole (or expense) of running a new circuit from the main consumer unit.
Is this safe/sensible and will it work? So I guess my questions are:
- will this fit with legal requirements?
- do I need an RCD in the shed as well as the one in the kitchen?
- is 2.5mm cable heavy enough for my requirements or do I need something thicker?
advice appreciated, thanks.
