Powering Shed for fish house. | Page 2 | on ElectriciansForums
Discuss Powering Shed for fish house. in the UK Electrical Forum area at ElectriciansForums.net
L
Leroy01
So my old man is planning on setting up a fish shed which will hold 2-3 fish tanks. The power drawn from the equipment which will be running in here are 2x 500w heaters, 10,000 ltr return pumps which are 80 Watts and a few lights which are 90 watts at max, Will most probably have 3-4 to start with.
So i know the idea would be to install an armored cable straight from the fuse board but running the cable through the house would be a nightmare so im planning on either running 2.5mm single core cables or an armored cable from a fused spur of a ring main but wondering what you guys think and if you think i should be ok ?
Would need to run 2-3 small led's for the shed itself and the outside but that's about it.
Reply to Powering Shed for fish house. in the UK Electrical Forum area at ElectriciansForums.net
Are you meaning running two 6mm cables in parallel? This is allowable in UK regs, providing the two runs are exactly the same length and routing...
If you think that's bad you should try manually winding out the safety curtain in a theatre.
davesparks
