Working on a very long property with thick stone walls so when away from the router and phone base station, both phone and wi-fi is poor to non-existent, it is even problematic on rooms adjoining where the router is
I have a tplink powerline adaptor which I happily use at home. I have also provided cat5 cable to enable the connection of range extenders.
Is there such a device which combines the two? I send the data stream around the mains cabling and plug in range extenders which then transmit? Or would I have to plug in a tp link at each point I wanted a range extender and connect to this with an ethernet cable from each tp link in which case would I be better off hardwiring in cat 5 from the hub? If hard wiring in cat 5 can I daisy chain?
The solution for the phone appears to be a 'long range cordless repeater bundle', unless anybody informs me otherwise!
Many thanks for any (simple) responses
