Powerline - slloooowww | on ElectriciansForums
Discuss Powerline - slloooowww in the UK Electrical Forum area at ElectriciansForums.net
P
Peter Cashen
Hi All,
I've posted in the relevant IT techy forums... I'm one myself, but got no answers.
Basically just moved into a new build (no Ethernet wiring unfortunately), but was going to use powerline adapters.
In my old house they worked fine and I'd get 150mb/s or more, but in this house they wont go over 70mb/s, so thinking that it must be to do with the electrics or RCD things.. I know nothing about electrics. Is this a known issue? Anything I can do/try?
Hi Peter and welcome to the Forum !
The starting place for me would be - what speed has BT (?) provided to my house? There should be a service test point - unplug any house wiring, measure from there and report back :)
Edit : as it may only be 70Mbps (you lucky person ...)
"Is this a local LAN / ethernet? I'd start by getting the earthing tested and check for a neutral-earth voltage that shouldn't be there."
Ok, this is what I was hoping for... I've no idea what this means... I'm an IT guy, and I've exhausted my IT technicalities! So it must be electrical...
How would I test this?
I'm presuming this is transfer speeds as you stated 150 mb/s.
I would try to narrow down, so try both adapters on the same circuit close together first. I.e same room as your router.
Hi,
So far I've literally had the two adapters in the same double socket with the laptop and router next to one another... no difference, still only around 30% of the expected speed.
I've also turned everything else off in the house to prevent interference/noise - no difference.
This is why I think its to do with the core wiring/electrical system.
If you have them in the same double socket it's not the wiring.
Reset both back to factory, check firmware, try a hammer.
Same router?
Try a different Ethernet cable?
If they are in the same socket, does that mean that everything is done within that socket and nothing goes near the RCDs or fusebox thing??
Both have been reset. Even tried a different pair and same issue.
Tried multiple cables.
I've ruled out router - definitely either plugs or core electrics.
Hammer isn't far off.
@Andy78 I've had good success, I wired a garage 120m away from the residence, it synced fast enough to browse/ YouTube etc.
I use them at home extensively as all my walls are solid so wifi drops out very quickly.
Hi.. sorry, missed that out.
Its Virgin... if I connect directly to the router then I get 225mb/s! I'm on the fastest BB.
225 megs a second....Jesus.... are you serious? I don't think our national backbone network runs at that speed. I just upgraded to 2 meg ADSL at home and that took some pulling of strings.
Unless you have serious noise on the line then yes I would say it rules out the fixed wiring.
What adapters are they?
Reply to Powerline - slloooowww in the UK Electrical Forum area at ElectriciansForums.net
I would have to agree with @James to hire an electrician to measure the voltage coming in to the panel. If you have 240vac phase to phase then you...
