ppe when performing live tests | on ElectriciansForums
Discuss ppe when performing live tests in the Australia area at ElectriciansForums.net
soulman
Durham
hi, do you guys where eye protection and insulated gloves when performing live tests ZE PFC etc;
cheers
not now but the firm I used to work for as a maintenace electrician insisted as it was "live working" it was a two man job. Believe me it never happened. I have worn rubbers when testing the Ze on the live incoming busbars to ACB's
Reply to ppe when performing live tests in the Australia area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
