Pre Assesment Checklist?? | on ElectriciansForums
Discuss Pre Assesment Checklist?? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
jasonc123
Hi lads
Does anyone have a pre assesment document checklist? We have been working our way through the mountains of paperwork that we believe we need prior to the assesment. But so far we have only been working from mcs 001 which as im sure your aware leaves it a bit to your imagination. Any help would be much appreciated.
ELECSA should have sent you a comprehensive list once you have paid. They then go through each clause sequentially using computer generated questions. Do yourself an audit from start to finish going through each point and youll be fine. Make sure you have internet access for the assessor. The only point I was picked up on was pertaining to my meeting minutes, I didnt list each individual clause in the check list as a bullet pointed list.....
If you did not write your MCS manual yourself, make sure you know it inside out as the complete audit is evidence based i.e. they need to see what is written
Reply to Pre Assesment Checklist?? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
