pre victorian wooden building | on ElectriciansForums
Discuss pre victorian wooden building in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DPhilpott
Hey guys, im starting a project where the building structures are as described above but at some point (possibly original) rendered on both sides. This is new to me and I would be really grateful of any info you may have for me. It is a high street and the owners would like brackets fixedto the outside walls of these properties
well you have lathe and plaster, straw and plaster and then wattle and daub
There are many ways building were built over the years
I honestly do not understand your original post, are you asking can you fix to them ? etc
We need a bit more info about the brackets size, weight, what they are supporting???????
Also a bit more info regarding the structure to be fixed to??????????
Read your post back to yourself & imagine you are reading it for the first time.
Now explain where the question is hidden!
Sorry about that guys :) I think when I wrote original post I was probably looking for inspiration or a place to start :) They want tree brackets and chrsitmas trees fixed to the surface, it is an odd structure. The internal walls seem to be block of some sort, maybe brick and outside is timber and render. Ive got to work out whether I fix to the studs or go deep i to the block. Then I may need some kind of coated fixing so not to get moisture below the surface. Am I complicating this? Am I missing something really obvious? Thanks
until you try a fixing or two you will never know !
resin fixings i have only ever used in cellars below the water table or have been tanked etc
Only you know the weight and the way the things you want to fix pull at the fixings
(If this building is on a road or high st etc where public have access then please be sure and make sure you have your insurance updated)
Reply to pre victorian wooden building in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
