Preferred Mains Smoke Detector brand? | on ElectriciansForums
Discuss Preferred Mains Smoke Detector brand? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
What's everyone's preference on mains interlinkable smoke/heat detectors taking into account price, reliability and look?
Ive used Aico several times and never had a problem but they are expensive and quite bulky!
Cheers
Fitted a few cheaper versions as well, hard to say anything bad about them as they work fine and haven't had any issues with them, BRK from screwfix are OK for the price, Kidde as well. I've also used really cheap ones from Yesss electrical, can't even remember the name, possibly firesafe...........cheap and cheerful but seem ok, I still stick to Aico though.
BRK are utter piece of crap!!!
had some purchased by tight wad customer recently, they came with a kind of connector with wires sticking out, to plug on the top of the unit and connect it up to the wiring. it sticks out a lot so the thing is not flush with the ceiling, looks like it requires their extra crappy plastic adaptor plate? Or a taped chocblock pushed into the ceiling void?
Ended up soldering their wires to my 3c+E cables and heatshrinking the lot...
Kiddie for me anytime, 2 piece - base has easy to install push-fit connection for one incoming and one outgoing cable, then you stick in the main part when the job is done.
the new aico E range are pretty good- used them a few times now
look bit more smarter
and the wireless bases are chips that go INTO the head- rather than having the old bulky wireless bases like before
ei166e, ei164e, ei100mrf
Reply to Preferred Mains Smoke Detector brand? in the UK Electrical Forum area at ElectriciansForums.net
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
