solidmik
could any body help on this matter please, as i have read the onsite guide and checked the wiring regs and came up with the same answer, Q, can u run cables behind skirting boards, they r 50m deep and protected by a rcd, the electrician said that you can run cables in any direction as long as the are protected by a rcd is this correct /
