Pressure reducer/regulator for plastic water line? plumbing advice | on ElectriciansForums
Discuss Pressure reducer/regulator for plastic water line? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Pressure reducer/regulator for plastic water line? Good evening,
Wondering if i could get a little guidance, I have a 3/8 plastic line running from a softener to a coffee machine (because laziness), however the line pressure seems to be maybe 2.5 bar. The manufacturer state the max line pressure is 2 bar (29 PSI). for the life of me i cant find a device to let me lower the pressure in the line which will connect to the 3/8 plastic line. im happy to throw on some adaptors, but it doesnt seem very easy to get a 3/6 push fit to 15mm thread adaptor.
could someone point me in the right direction?
Cheers
Pressure reducer/regulator for plastic water line? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Pressure reducer/regulator for plastic water line? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
T
PRV with Gauge Question Hi, I have a Caffeli PRV near the mains stopcock. Static pressure fluctuates between 3-4 Bar and when a tap is opened it...
techweb
T
A
Cold water flowing back into hot feed. Hi, I'd be grateful for some advice please. Every 12- 18 months I have a problem with cold water flowing...
Askey
A
