Pretty Sure This is Wrong............... | on ElectriciansForums
Discuss Pretty Sure This is Wrong............... in the Australia area at ElectriciansForums.net
C
Crosswire
Saw a DB in a new build flat today (before tenant moved in).
Was a standard dual RCD board, but the circuit supplying the fridge was not on either RCD
Was run in twin and earth in plasterboard walls same as other circuits, not in swa or surface
Now I can see WHY they did this - to preserve food in case of RCD trip - But surely this doesn't comply?
And before anyone says they future tenant will be a 'skilled or instructed person'
a) obviously they are not
b) if they are, then all circuits would not have to be RCD protected?
Any thoughts?
No was standard MCB,
To be honest I couldn't see inside wall, MAY have been in galv conduit I can't say for certain. Will try to find out over next few days, but my gut feeling is that it is unlikely
think you'll find most studded walls are made of 75mm x 50mm timber so if the cables are installed smack in the center of the stud it will be 37.5mm from either side of the stud so not at a depth of 50mm
the only reason an RCD is fitted to non-socket circuits is because of the 50mm rule. we still have to fit to socket circuits up to 32A for use by ordinary persons. ( 20A if indoors and not intended for outside use )
add 1" for the plasterboard, ( both sides) and you just get 4" or 100mm.
The quicker RCBO's become cheaper the better!
I'd love to walk into B&Q one day and see...'10 way Dist. Board inc your choice of RCBO's for ÂŁ60'
Saying that I can't wait to walk into B&Q and not see a single electrical item other a man behind a desk to which you have to show your ID too, who then lets you into the 'Electricians Section' :)
Reply to Pretty Sure This is Wrong............... in the Australia area at ElectriciansForums.net
