price check- domestic | on ElectriciansForums
Discuss price check- domestic in the Domestic Electrician Forum area at ElectriciansForums.net
J.C.E
Earth
Loft and kitchen extension plus some renovation in exisitng
London
no making good
brushed chrome raised edge with brushed chrome LEDs downlights
Basement
Install 1x 15way dual RCD metal MK consumer unit
Install mains gas and water bonding
Testing and certification on completion and after full payment is received
Install 2x d.sockets below consumer unit and 1x 4ft LED strip light+ 1gang switch
Kitchen
18x downlights -to be on 1 dimmer
2x pendant lights over island- to be on 2nd dimmer
13x d.sockets (amount TBC- Appliances to be on grid setup as below)
1x 45a cooker circuit+ isolator switch
1x gas hob circuit+ isolator switch (different if electric)
1x s.socket and isolator switch for microwave
1x s.socket and isolator switch for washing machine
1x s.socket and isolator switch for dishwasher
1x s.socket and isolator switch for tumble dryer
1x s.socket and isolator switch for fridge/freezer
1x s.socket and isolator switch for extractor hood (duct/vent to outside to be provided by builder)
1x s.socket and isolator switch for heated tap
-All above isolator switches to be hidden in one cupboard with white plastic finish (Grid Switch)
1x mains operated heat detector
2x standard Coaxial aerial outlets (TBC- where these are to run back to?)*
2x CAT5 data outlets (TBC- where these are to run back to?)
Living Room/Lounge
2x pendant lights+ 1gang 1way dimmer switch
5x d.sockets
Relocate NTL and Virgin Media points slightly to left- just under window bay?
1x mains operated smoke detector (TBC- Unnecessary)
W/C
1x pendant light + 1gang light switch
1x extractor fan+ isolator switch above outside door- (duct/vent to outside to be provided by builder)
1x 13a switch fuse spur for Megaflo (Spec requirements TBC)
Ground Floor Hall
1x outside light+ switch inside hall
1x 6amp feed for video door entry (Spec requirements TBC)
Loft Landing
1x d.socket
1x mains power smoke detector (+1 on 1st floor landing)
1x pendant light+ 2way switching with 1st floor landing
Loft Bathroom
5x IP65 downlights+ wall switch outside
1x shaver point
1x 6amp feed for mirror
1x fuse spur+ digital programer + 3m2 UFH kit- builder to ply/self level compound etc
1x fuse spur for towel rail
Loft Bedroom
9x d.sockets
7x downlights+ 2way switch (by bed and by door)
Loft Storage
1x d.socket for TV aerial amp (TBC)- amp not included
Go on then.... What's yours?
Will the place have no residence?
Just out of interest, are these all going on an RFC, or as some people like doing, on their own individual Radials?
Reply to price check- domestic in the Domestic Electrician Forum area at ElectriciansForums.net
