Hi all,
Don't think I'm duplicating here but if I am feel free to delete,
my boss asked me to work out the size of a SWA feeding an extension to a commercial property, basically the contractor wants to get the cable in, before the building design has been finalised, so we're basically playing it safe with the cable size, basically allowing X amount of Watts per meter for lighting and small power, allowing X amount of KVA for mechanical gear, X amount of KVA for kitchen gear etc. then to work out the size of the cable from there, Basically I need someone to tell me if I'm on the right lines, as my boss has had to go out tomorrow so isn't able to check and I don't want to base the rest of my day on the wrong calcs.
Heres what I did,
find the length of the cable run,
find the floor area of the new extension,
Multiply the watts per meter by the floor area. Then convert that to Amps using the 3phase conversion method,
Convert the KVA to amps again using the 3ph method
total up the load, then size the cable accordingly (taking into account lengths, and other factors)
The bit I wasn't really sure about was converting the Watts and KVA to 3ph or Single phase.
I apologise for the long, possibly confusing thread, but if anyone can tell me if I'm going in roughly the right direction that'd be great.
Heres what I did,
