genlabs
I am working within a project that involves access control and video, in a Georgia facility.
Another unrelated installer is using properly sized generic cabinets with steel backplanes.
I observed the low voltage components (logic controller, dry contact relay boards, etc) are being mounted with magnetic standoffs.
That is, the entire board can be pulled off the backplane and repositioned, if needed.
Seems like a novel approach for low voltage items.
When I saw the same standoffs being used with power supply boards my eyebrows started to raise.
The power supplies have "safe-to-touch" input blocks however those input blocks are soldered to the PCB and the bottom traces are fully exposed.
If the PCB was using conventional brass or nylon stand-offs this would not be an issue.
However the use of magnetic standoffs has me questioning the safety.
Although the magnets have good holding force I have to believe there is a written standard for this, especially when 120VAC mains is involved.
Do you know if this is a violation? Could you direct me to a document where this standard is published?
This situation can be corrected if necessary but I would like to have evidence in hand before approaching the installer.
Thanks!
Thanks!
- TL;DR
- Are magnetic standoffs instead of permanent standoffs an accepted practice when used with boards that have exposed high voltage traces involved?
