Discuss Problem Building my own electric skateboard in the UK Electrical Forum area at ElectriciansForums.net
Going to want a very long extension lead Mate
That's right skate around the problem, why don't youSounds like a bit of an uphill problem to me!
Think I'm getting a bit bored with this post, far too much slipping and sliding for my liking.sounds like OP has been a cheapskate here.
No mate keep tripping over the bluudy leaddoes it grind on your nerves.
well then what ESC do i need to buy for it to work smooth?Well it looks like the ESC won't get the best out of the motor although it should work. At a quick glance you have a sensored motor but a sensorless ESC, so it will behave as a sensorless motor and may give cogging efffects. Also, the ESC is only rated for 6S LiPo (i.e. 6 cells in series) but you need 8 to get max power from the motor. Be generous with the ESC rating if you want long life and reliability.
Reply to Problem Building my own electric skateboard in the UK Electrical Forum area at ElectriciansForums.net
