Problem chandelier? | on ElectriciansForums
Discuss Problem chandelier? in the Australia area at ElectriciansForums.net
R
rocker
Anyone got any ideas about this? I've got a chandelier which has 8 bulbs. Apparently, every month or so, the customer has to replace all the bulbs, and they are all blowing at the same time. It's probably blindingly simple but I can't het my head around it....
More frequent lamp failure can occur if lamps are not operated in their optimum burn position
Have seen problems caused by bad / burnt connections at the lamp holders which has required a rewire of the fitting
They are candle lamps, and yes they are 40w. They seem to be OK lamps (at least not your usual 20-for-a-quid jobbies). It is in a hallway, so it's on a lot. When you say optimum burn position, do you mean 'facing downwards'? These are facing upwards, and I have heard many times that this can shorten the life of the bulb...
The only thing puzzling me though is that they all go at exactly the same time.
Have you checked the lampholder connections and/or cable joints on the chandelier had something similar many years ago and had to rewire the fitting with high temp cable to clear the frequent lamp failures
The only other time I had frequent lamp failures was on a CCTV system it took six months and one very late night call out to resolve a camera failure. Doing all the normal checks found a blown fuse and then did all the normal tests and checks before replacing the fuse and then checked supply voltage at 266v. When reported to the electrical engineers it transpired that six months earlier new automatic tapping 11Kv transformers had been installed on this site and were not tapping down correctly as load was switched off this resulted in a single phase peak voltage of 273 volts on one occasion and one hell of lamp bill with lamps at ÂŁ30 each
So it could be a voltage problem that you will only find with a datalogger over a period of time
Marvellous! and I bet a datalogger ain't cheap!
I've had a look at the fittings - they look OK no melting, no soot or blackening. Voltage was 244 when I was there so shouldn't be causing any problems.... hmmm very strange. Nothing else in the house is having this problem, could be a combination of high peaking and rubbish bulbs I spose... I think I'll have to strip down he fixture and have a proper look at it (if I can), but any other suggetsions will be welcome in the interim!
I suggest you change the lamps to 15w rocker , 40w in a candle lamp is a no no ( unless your a lamp supplier)
Reply to Problem chandelier? in the Australia area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
