Problem Low voltage boiler mains cable | on ElectriciansForums
Discuss Problem Low voltage boiler mains cable in the Central Heating Systems area at ElectriciansForums.net
J
joe kane
Hello everyone.This is the 2nd time ive had this problem.
I have a 240v supply to the boiler,but it needs a 24v supply(call for heat)Someone said to me an external relay is needed.
But I don,t know what sort,and don,t know how to connect it,Please help.
How did you overcome the problem the first time?
Is it not a link in the boiler control panel to be removed if a thermostat is used?
it is for underfloor heating,first time wiring it and given wrong instructions by plumber.A wire was left out from manifold to boiler call so i need to turn it on only have a mains supply of 240v but need to turn boiler on 24v in.
if the link is taken out the boiler turns off.
Although the boiler has a 24v supply at link,can i return this call to other side of link via relay with a 240v coil and 0v contact
I would make a quick call to the boiler manufacturer's technical department and just double check what you're proposing, better safe than sorry.
Sounds similar to a boiler I recently did. Sent a 3 core to the boiler as normal from the system controls only to find the boiler had a volt free call circuit. Due to the system having multiple zone valves and pumps the only option was to fit a relay in line with the volt free contacts with the coil powered by the switch live I had already installed. Should work in this case too but it might help to let us know what boiler has been fitted to advise better.
Reply to Problem Low voltage boiler mains cable in the Central Heating Systems area at ElectriciansForums.net
I
Baxi system boiler and Opentherm Hello Does anyone know if its possible to connect an Opentherm thermostat such as a Nest to a Baxi 800 System...
Ian777
I
H
Combi boiler problem Hi this is my first post so please be gentle. I have a Worcester greenstar 28i junior combi fitted in my house, we were...
Happyharry
H
