problem with 60 amp fuse | on ElectriciansForums
Discuss problem with 60 amp fuse in the UK Electrical Forum area at ElectriciansForums.net
West Midlands
I changed two fuse boards in a house that is converted into 6 flats, these 2 boards control the communal lighting, which work on PIR sensors, so are never left on for long, they also control the fire alarm, emergency lights and the immersion heaters, one on each board.
So in each fuse board we have a 32 amp ring, a 16 amp water heater circuit, a 16 amp radial socket circuit and 2 lighting(6 amp) circuits.
When i turn the power on everything is fine, but then when i leave the job, an hour or so later i have the landlord on the phone saying nothings working, when i go back the 60 amp fuse has blown, but it seems to take an hour or 2 to blow, can anyone shed any light on this for me as i've been back 3 times now and am going out of my mind.
thanx, james.​
^^^^^^^^^^^^^^As above^^^^^^^^^^^^^
Check for extension leads coming off sockets in communal areas (the landlord pays the bill for each flats electricity).
Worth staying around for an hour with your clip on Amp meter.
I had this problem before and it turned out that they supply cable from the fuse to the ccu had a snip where someone had cut of sheath and was arking cauding the fuse to blow you need to do an isulation resistance test on the cable or if its before the meter call dno
Reply to problem with 60 amp fuse in the UK Electrical Forum area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
