P
Piratepete
Hi
I'm investigating a Fully pumped Honeywell Sundial Y plan system with a mid position zone valve. The customer only had hot water.
I found that the motor on the valve was knackered and changed it. I also had to replace the Sundial Wiring Centre and swopped the wiring over one for one (I think).
The problem now is that though there is now hot water and heating with the thermostats seeming to operate correctly, the programmer won't turn off the system once it switches on.
It seems clear to me that there is feedback from somewhere which latches the circuit permanently 'on'. I've checked the connections and all seems ok. Can it be another fault in the valve - switches or circuit board doing this? I don't fully understand when the 2 microswitches operate.
Getting desperate.
Pete :cry_smile:
Getting desperate.
Pete :cry_smile:
