R
RichardClarke
Within my kitchen I had installed 2 sets of Halogen Cable Lights, each containing 5 halogen lights each light is 50 watt. At the end of each kit is a 12v transformer which is connected to the mains. These lights were installed approximately 2 years ago. As readers will be aware there are 2 pieces of wire that run from the transformer to each end of the cable lights to form a circuit. Here lies the problem...recently one of the cable lights has stopped working and on further inspection the problem is a break in the circuit namely one of the wires from the transformer appears to have burnt out and detached itself from the cable lights. The other set of lights is still working but the same wire for that set appears to be black in colour and is no doubt going the same way.
If anyone can help, I'd like to know if this is a common problem with these sort of lights or is it a manufacturers problem or a problem caused by the installation. In order to mend the lights I assume I need some sort of insulated wire to replace the burnt out one...any ideas what sort of wire I use ?
Thanks in anticipation.
