Problem with PIR light | on ElectriciansForums
Discuss Problem with PIR light in the DIY Electrical Advice area at ElectriciansForums.net
Peep
Surrey
Hi guys,
I'm new here and would welcome some advice.
I'm an amateur, replacing an external light. The light is PIR activated only, and is not switched.
It used to be plugged into a 13 amp socket, but I have removed the socket and replaced it with a switched fused spur, with a 5amp fuse.
There is power going into the fused spur, and power going out of it to the fitting. However, the light does not come on.
I have checked the bulb and taken the cable out of the spur and wired it into a 13 amp plug. When I plug this into a socket, the lamp comes on.
There is a set of connector blocks in the fitting marked L, N, E and X. X goes to the PIR.. I have connected the Brown to L, Blue to N and Yellow/Green to E. The other internal cables were pre-wired.
Can anyone offer any help, please?
Thanks for your time.
blown fuse in FCU?
I'm afraid not. The fuse is fine, (I changed it anyway) and the power is definitely going to the light
faulty FCU. no neutral? how have you tested for voltage to fitting? voltstick will only detect L.
Agree with Tel, you need to test across live + neutral on the load side of the spur and check you have correct voltage.
Good idea, but I made sure the flex power in was properly connected. The wires in the fitting have a solid casing oo the ends, and I've made sure all the screws are down tight and given the cables a bit of a tug to make sure they are firm
Most external PIR lights are now switchable, manual / automatic. They don"t have a separate switch wire it's all dealt with on a switched live, the switching sequence selects manual or automatic operation. Is it in the correct mode, switching it off and leaving it for 30 secs should reset it to automatic. Switch on/off/on within 20 secs will set it in manual mode. They should be wired through a switched fcu to enable switching between automatic and manual operation for testing.
Reply to Problem with PIR light in the DIY Electrical Advice area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E. Kitchen is being...
