C
collin1443
Hi there,
I have a ----y problem as follows:
I have a ABB disconnect switch Fused at 60A, supplying 3 phase 575V(North America) to a Power Cabinet.
The Power Cabinet has several motors and a 6000VA transformer, that steps down the voltage to 230VAC/120VAC single phase.
The Cabinet also powers another Cabinet, a 15A Control Cabinet at 120VAC
Twice now, the fuses on the Power Cabinet have blown on the primary side of the transformer, and 2 VFD's
when the ABB disconnect is either being closed or opened.(We turn the disconnect off at night, and turn it on in the morning. It has only happened 2x but we have closed the disconnect probably 30-40X already.
The Transformer is fused as 6000/575V = 12A Time Delay
The 2 Motor VFD's are both 2A, and are Fused at 3.5A
What could be causing the Fuses to blow? is the transformer surging the 3 phase line?
The whole 3phase line seems to be surging, since the transformer, and the 2 motor VFD's are
the only device drawing current in the Cabinet.
Any suggestions to debug this issue?
Collin
Collin
