steve14
Hi,
I recently setup a grid tie solar system using 4x 100W Biard solar panels from eBay, I'm using a Stecagrid 500 inverter however after connecting it all up the inverters LED is flashing green, which according to the manual means its in Stand-by as there's not enough power coming in. I thought 400W would be enough for the inverter to work.
The panels are setup in series and I'm getting about 82V off them, the inverters manual says the minimum voltage is 75V so it should be working.
Is there something wrong with my setup?
![steca.jpg steca.jpg](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/17/17187-36324d57145a3b281b0593fb09f6e594.jpg?hash=NjJNVxRaOy)
